Viewing and Managing Application Topic Usages
On the Applications tab, you can view the input and output topic usages of an application.
1. On the Applications tab, right-click on an application and select Topic Usage on the context menu.
The <Application Name> Topics dialog displays.
If the application has been executed, the #Messages column will display the number of retrieved messages, while the Messages/sec column will display the number of retrieved messages per second.
If the application is not yet executed, both the #Messages and Messages/sec columns will display 0 values.
2. You can then opt to:
3. Click Close.
