Add Redmark
- Writer, Date, Permission will be applied automatically. Give the Title, Step, Layer.
- Enter the content here.
- Can add the drawing objects (Line, Circle, Freeform, Text) on the target layer and location.
- Attach File: Can attached relevant files.
- Draw: Select the drawing objects and then draw by clicking mouse left button. It can support to use line arrow for start point or end point. Can choose the color and line width of drawing objects.
- Text: Text message into content box. Text will be put on the target
layer and location. Can edit the content by mouse double click on text
box, drag the text box to move the text location.
Figure 2. - Measure: Can measure the size and the distance between object to object.
The measured value will be displayed on Property section.
- Object: Can measure the width and height.
- Object to Object: Can measure the distance between object to object.
- Edge to Edge: Can measure the distance from edge to edge of each object.
- Center to Center: Can measure the distance from center to center of each object.
- Minimum Distance: Can measure the minimum distance between object to object.
- Point to Point: Can measure the distance between point to point of each object.
- Apply: Click Apply to maintain the measured value. Can support to measure and maintain for multiple values.
