To solve a model with the volume equivalence principle (VEP), you must activate VEP
for each relevant region.
Select the region (or regions) in the 3D view or in the
details tree that you want to solve with VEP.
In the details tree, from the right-click context menu, select Properties.
On the Modify Region dialog, click the
Solution tab.
Under Solution method, from the drop-down list, select MoM/MLFMM with volume
equivalence principle (VEP).
Figure 1. The Modify Region dialog
(Solution tab).
Click OK to save the region properties and to
close the dialog.
