Numerical Green's Function (NGF)
In the solution of large electromagnetic problems solved using the method of moments (MoM), sometimes a considerable part of the geometry remains unchanged, while only a small part changes. The unchanged part (static interaction matrix) can be saved to a .ngf file and reused to reduce CPU time.
Tip: To obtain a reduction in CPU time, domain decomposition is recommended for
MoM models consisting of a large static part and a
smaller dynamic part.
A static part is indicated by the The following restrictions apply with respect to the NGF:
- The NGF can only be activated on a part. Selecting a sub-part and activating the NGF will activate the NGF for the entire part.
- The NGF is not supported in conjunction with continuous frequency simulations.
- When the NGF is activated for a part, the following cannot be modified:
- geometry
- the solution method
- media
- ports added or deleted
- loads
- transmission lines
- general networks
