GPU CUDA API Guide
Given that the custom API scripts are called and run on the GPU, they must be declared as __device__ functions as follows:
__device__
void calculateForce(NCudaApiTypesV1_0_0::CApiElement& element1,
NCudaApiTypesV1_0_0::CApiElement& element2,
There are other function declarations such as __Global__ and __Host__.However they are not required.
CUDA Programming Style
The CUDA API is closer to the C++ programming, in terms of style compared to the OpenCL API. This means that basic operations usually take a much simpler form.
Some examples of the functions are as follows:
| Type of function | OpenCL function | CUDA function |
| Vector arithmetic | vvSubtract(a,b) | a - b |
| vvAdd(a,b) | a + b | |
| vecMultiply(a,b) | a * b | |
| vecDivide(a,b) | a / b | |
| Vector operations | vvDot(a,b) | a.dot(b) |
| vvCross(a,b) | a.cross(b) | |
| vecNormalize(a) | a.normalize() |
For a complete explanation of the available functions, see the API help documentation at the following location:
<EDEM install directory>\202X.X\EDEM\src\Api\Help.
CUDA Class Declarations
Multiple different particle types can be used with the CUDA API whilst only multi-spheres operate on the OpenCL API. Given this difference, the CUDA API operates with a more generalized set of classes and functions compared to OpenCL.
There are some differences which stem from CUDA’s programming syntax compared to OpenCL’s. However there are other differences which originate directly from EDEM. For example, when retrieving the radius of an element in CUDA for a Multi-Sphere or a Sphero-Cylinder the following operation would be used:
element1.getPhysicalRadius() ;
The closest equivalent operation which would work for polyhedral particles is:
element1.getVolumeSphereRadius();
This is not a syntactical difference, but rather a real difference in the value. In this case it is due to the fact that Polyhedral particles do not have an inherent radius like Multi-Spheres and Sphero-Cylinders do.
Therefore when developing API scripts on CUDA, the following resources are helpful in understanding the available functionality:
- The internal EDEM API documentation
This details the EDEM specific CUDA functions and classes. This can be found at the following location: <EDEM install directory>\202X.X\EDEM\src\Api\Help.Then select any html file. - CUDA Documentation
This details standard CUDA functionality.
For the complete documentation, see https://docs.nvidia.com/cuda/index.html - Example code can be found on the Altair community page: https://community.altair.com/community.
The following example codes provide an insight into how these different functions should be implemented.
CUDA Getter and Setter Functions
In order to maintain backward compatibility going forwards with the CUDA API, a range of getter and setter functions have been implemented. These allow you to retrieve the same information they could using the OpenCL solver.
element1->position;
Is equivalent to:
element1.getPosition();
CUDA Debugging
This is similar to the OpenCL debugging process. If errors are present EDEM will detail the errors in a dialog box when your simulation is started. An additional method for debugging which allows a user to gain real time information from the simulation is to run an attached simulation through the command line.
To debug CUDA:
- Add printf() functions as desired throughout your API to output values of interest.
- Locate your EDEM.exe directory at “<EDEM install directory>\202X.X\EDEM\bin\”.
- Run the command EDEM.exe --no-free as such: C:\Program Files\Altair\2022.3\EDEM\bin\edem.exe --no-free
- Load your API model into EDEM and run the simulation.
The results of the output should be displayed in the command window.
CUDA Main Functions
Due to the differences in classes and data types between the CUDA file and the multi-sphere OpenCL file, modifications need to be made to the ExternalForce and CalculateForce functions. The main function naming in the CUDA API follows a different convention to the OpenCL API. In the CUDA file, the file name should not prefix the main function names.
Examples of these modified main function inputs are as follows:
__device__
NCudaApiTypesV1_0_0::CApiInteraction& interaction,
NCudaApiTypesV1_0_0::CApiContact& contactData,
NCudaApiTypesV1_0_0::CApiSimulation& simulationData,
NCudaApiTypesV1_0_0::CApiContactResults& contactResult)
__device__
void externalForce(NCudaApiTypesV1_0_0::CApiParticle& particle,
NCudaApiTypesV1_0_0::CApiSimulation& simulation,
NCudaApiTypesV1_0_0::CApiTotalForce& result)
In addition to these functions, the configForTimestep functions allow custom functionality to be modified at each Time Step. Even if they are not used, it is mandatory to include these functions:
__device__
void configForTimeStepParticleProperty(NCudaApiTypesV1_0_0::CApiCustomPropertyData& particleProperties)
__device__
void configForTimeStepTriangleProperty(NCudaApiTypesV1_0_0::CApiCustomPropertyData& triangleProperties)
The configForTimeStepParticleProperty is used for both contact and external force models, so when it is used in a plugin that combines calculateForce and externalForce models, those models must have the same custom properties and custom property order, otherwise the wrong values can get modified.
The configForTimeStepTriangleProperty does not get the actual element custom property values, rather the difference between values between timesteps (this is not the same as triangle contact deltas). This was done for easier mGPU implementation as the triangle custom property values are unused in any calculations, as they are intended for post-simulation analysis.
CUDA Data Precision
In the CUDA API, you can specify the precision that you want their data to be handled with. This allows API scripts to take advantage of the speed benefits of the hybrid and single precision solvers. The three CUDA specific data types are: real, longReal, and customPropReal.
The following table shows each data type’s precision depending on the solver settings.
| Data Type | Solver Precision | Usage | ||
| Double | Hybrid | Single | ||
| real | double | single | single | Most situations |
| longReal | double | double | single | High precision data requirements |
| customPropReal | double | double | single | custom properties |
To implement these data types, specify them when declaring a variable as follows:
real exampleVariable = ...
Here, the real data type is used, and is an appropriate datatype for most situations. For more information about these data types and the functions associated with them, see the API help documentation.
CUDA Asserts
An option to enable asserts for enhanced error diagnostics has been added to the CUDA solver. Enabling this causes a minor slowdown in simulation performance. This can be enabled from the GUI in the Simulator > Advanced Setting... window, or from the command line using the option "--cuda-asserts 1". In order to use this effectively, EDEM should be running a command line simulation or EDEM should be started from the command line using the option --no-free, so that any additional console output from an assert can be sent to EDEM support.
CUDA Header Files
The Header files for the EDEM CUDA API are now located at:
INSTALL_DIRECTORY\EDEM\src\Api\Cuda
These files are not required to develop a CUDA API plugin, but can be used to get a better editing experience
including syntax highlighting and intellisense. They also allow API users to quickly get the most recent versions of the various CUDA functions that have been added in between releases.
To use these Header files:
- Copy the example file examplePlugin.cu to a location in your documents where you are developing the plugin.
- Rename the file based on what plugin you are developing.
(The name must match the name specified by the getGpuFileName function in the CPU part of the plugin.) - Open the file with your code editor. If your code editor uses a project system add it to the project.
- Add an include directory path in the code editor linking to the folder INSTALL_DIRECTORY\EDEM\src\Api\Cuda.
This is needed so that the #include directives in the example plugin file can be resolved.
These #include directives are not needed to make the plugin run in EDEM but are needed to get syntax highlighting in the code editor. - Set the code editor options to interpret *.cu and *.cuh files as c++ files.
- You can now prototype a CUDA plugin with syntax highlighting and intellisense available. Installation of the CUDA toolkit is not required.
Sphero-Cylinders
API users should be cautious when implementing contact models for the CUDA solver to not rely on the contact normal being in the same direction as the vector from the API element 'position' member to the contact point. While this does work for Multi-Sphere shapes, it will not work for Sphero-Cylinder or Polyhedral shapes. Users should instead try to use the contactNormal member which is passed in the overlapData API structure.
Apart from this, all contact properties for Sphero-Cylinders have a similar definition to those for Multi-Sphere particles.
