Adding Sphero-Cylinder Particles
The length is given by the total length of the particle including the rounded ends. EDEM supports switching between Multi-Sphere, Sphero-Cylinder, and Polyhedral particles only at Time Step 0s.
Adding a Sphero-Cylinder Particle
Right-click Bulk Material and select Add Sphero-Cylinder Particle or click the
icon.
This creates a new particle shape in the Creator Window.
