The EDEM Cal Utility
The utility removes manual steps from setting up and running multiple EDEM simulations. EDEM Cal can create and submit parameter space searches automatically. EDEM Cal collates automated results from EDEM analysis and supports the use of EDEMpy scripts to obtain results, significantly reducing engineering time needed. At the moment EDEM Cal is a windows only application, but can generate a batch job for Linux.
The workflow for EDEM Cal is as follows:
EDEM Cal Interface
The following image represents the EDEM Cal interface with the Menu bar (1) and Toolbar (2).
The Menu bar contains the following:
Help
Shows the details of the EDEMCal software.
The Toolbar
Comprises icons to change the User Interface to generate EDEM simulations, execute the simulations and compile the results.
| Icon | Action |
Load Deck |
Parameter Editor |
| Post Processing | |
| Processing Options | |
| Submit job | |
Results Analysis |
