Particle Body Force User Defined Libraries (UDL)
Using the EDEM API, you can write and compile custom particle body forces as a UDL written in C/C++.
Creating a New Particle Body Force UDL
- Create a directory to contain the new Particle Body Force project.
- Copy the following header files into the directory:
- IPluginParticleBodyForce.h
- PluginParticleBodyForceCore.h
- IPluginParticleBodyForceV3_3_0.h
- PluginConstants.h
- Helpers.h
- Create a new class (CNewParticleBodyForce) derived from the particle body force interface you want to use (for example, IPluginParticleBodyForceV3_3_0).
- Save the Class declaration (consisting of declarations of the methods in the chosen interface and any extra methods needed for your functionality and any variables) to a header file (for example, CNewParticleBodyForce.h).
- Implement all of the methods defined in your header file and save as a cpp file (for example, CNewParticleBodyForce.cpp).
- Create a new .cpp file with implementations of the methods in PluginParticleBodyForceCore.h. Save as NewParticleBodyForce.cpp.
- Use command line or create a Makefile (or equivalent) to build and compile .dll (Windows) or .so (Linux) library files.
- Ensure that the library and optional preferences file are in the particle body force model folder (as specified with Tools > Options > File Locations) or in the same folder as the simulation_name.dem file (only for versions EDEM 2017 onwards).
- Start EDEM and then select the required particle body force model category from the Interaction pull-down in the Physics section.
- Click the + dropdown and then select the new particle body force model.
Particle Body Force API v3.3.0
The interface IPluginParticleBodyForceV3_3_0 provides these methods:
| Method | Description | Type |
| getPreferenceFileName | Retrieves the name of the config file used by the UDL. | Setup |
| isThreadSafe | If the UDL calculateForce() method is thread-safe then this method must return true. Thread safe programming requires a number of conventions and restrictions to be followed. If in doubt, set this to return false. |
Setup |
| usesCustomProperties | Indicates whether the UDL wishes to register or receive custom property data. | Setup |
| setFilePath | Called inside starting() method to provide the plugin with the full simulation path (including the simulation filename). | Setup |
| getGpuFileName | Initializes GPU plugin by accepting cl file name without extension. If empty, the model will not be supported on the GPU solver. | Setup |
| setup | Initializes the UDL by giving it a chance to read any config files, open temporary files, generate data structures or any other one off setup work. | Setup |
| starting | Called once at the start of the simulation to indicate processing is about to begin and the model should allocate any temporary storage and retrieve any file/api/socket handles it may need. | Simulation |
| stopping | Called once at the end of the simulation to indicate processing is finished and that the model should free any temporary storage and close/release file/api/socket handles. | Simulation |
| externalForce | Called every single Time Step for every single particle. It allows you to add a particle body forces (for example, electromagnetic force, drag force) to particles. This is not used by CUDA solvers and should be left empty. |
Simulation |
| getNumberOfRequiredProperties | Returns the number of custom properties this UDL wants to register with the system. | Setup |
| getDetailsForProperty | Retrieves details for a given property. These properties will then be registered with the system if they do not clash with any existing properties. | Setup |
| configForTimeStep | Called during processing, at the start of each Time Step. This should be empty for CUDA solvers and implemented in the CUDA file instead. |
Simulation |
| getParticleParameterData | Retrieves particle parameter data in a buffer format. | Setup |
| getSimulationParameterData | Retrieves simulation parameter data in a buffer format. | Setup |
| processParticleOfInterest | Process particles that were marked for additional processing in externalForce call. | Simulation |
Methods of type 'Setup' are called only once at the start of a simulation, whereas those of type 'Simulation' are called during the simulation.
See the API documentation for more details.
