Selecting Units
Select Tools > Options > Units to change units individually, or otherwise.
By default, all quantities are measured in standard SI units (Système International d'Unités).
Changes are applied throughout EDEM*.
| Property | Available Units | SI Unit |
| Acceleration | mm/s2, cm/s2, m/s2, in/s2, ft/s2, fpm/s, μm/s² | m/s2 |
| Angle | rad, deg | rad |
| Angular Acceleration | rad/s2, deg/s2 | rad/s2 |
| Angular Velocity | rad/s, deg/s, rpm | rad/s |
| Charge | nC, C | C |
| Density | g/cm3, kg/m3, lb/in3, lb/ft3, slug/ft3 |
kg/m3 |
| Energy | J, erg, kwh, btu, ft-lbf, in-lbf | J |
| Force | N, dyn, kgf, lbf, ozf, pdl, gf | N |
| Frequency | Hz, kHz, mHz | Hz |
| Heat Flux | W, J/S | W |
| Length | mm, cm, m, in, ft, μm | m |
| Mass | mg, g, kg, lb, oz | kg |
| Mass Flow Rate | mg/s, g/s, kg/s, lb/s, oz/s, mg/min, g/min, kg/min, lb/min, oz/min, kg/h, uk ton/h, us ton/h, metric tonne/h | kg/s |
| Moment of Inertia | lb/ft2, kg/m2, g/cm2, lb/in2, slug/ft2 | kg/m2 |
| Pressure | Pa, N/m2, dyn/cm2, kp/cm2, atm, Torr, lb/in2 | Pa |
| Shear Modulus | Pa, ksi | Pa |
| Stiffness | N/m, lb/ft | N/m |
| Stress | Pa, Nm2, lb/in2 | Pa |
| Temperature | K, oC, oF | K |
| Time | s, min | s |
| Torque | Nm, Dyne.cm, gf-cm, kgf-m, lbf-in, lbf-ft | Nm |
| Velocity | mm/s, cm/s, m/s, in/s, ft/s, ft/min, μm/s | m/s |
| Volume | mm3, cm3, m3, in3, ft3, L , μm³ | m3 |
| Work Function | J, eV | J |
*Graphs are not automatically updated when units are changed. Once units have been changed, click Create Graph to regenerate graphs.
