You can export the data collected during your simulation for analysis. Data can be exported from a single Time Step, a range of time steps, from all elements in your model, or just from a selection or bin group.
Exporting data is carried out using queries. A query is used to define a single element attribute. For example, a query could be set up to extract the x-position of particles of type A in your model. Multiple queries can be grouped together under one Configuration ID and exported to a single file.
A configuration can contain multiple queries, each of which defines one data attribute. Queries define what information is exported.
Query Type
Used to determine which data values will be exported for a particular attribute. For example, if a query has been set up to export the velocity of particles of type A, you can select to export the maximum, minimum or average velocity per Time Step.
The following data is exported for each query type:
To specify a value range for the data exported, select the Specify Range checkbox to limit the export to data that falls between two specified values. For example, only exporting particle velocity data for particles traveling between 3m/s and 5m/s.
Similarly, you can create further queries. Once all the queries have been set up, click Export to export your data to your specified file. For more information on attributes, see Appendix A: Attribute Definitions.
Collision Elements
Affects all or any combination of specific particles types or geometry sections.
| Attribute | Components | Query Type |
Average normal force |
Magnitude, X, Y, Z |
Standard, Avg., Total, Min. or Max |
Average tangential force |
Duration |
N/A |
Standard, Avg., Min. or Max |
End time. |
N/A |
N/A |
ID |
N/A |
N/A |
ID Element n. |
N/A |
N/A |
Maximum normal force |
Maximum tangential force |
Normal energy loss |
N/A |
Number of collisions |
N/A |
N/A |
Position |
X, Y, Z |
N/A |
Relative velocity. |
Relative velocity normal |
Relative velocity tangential |
Start time |
N/A |
N/A |
Tangential energy loss |
N/A |
Total energy loss |
N/A |
Velocity of element A |
Velocity of element B |
Torque query standard, average, maximum, or minimum will provide the torque values based on the individual triangular elements. The torque Specify Axis option is recommended or alternatively the torque Total via a specific axis.
Torque Query Type Total Component X, Y or Z for a named geometry component (e.g. screw blade) will provide a resulting torque values along the X,Y or Z axis for the geometry component through the geometry Center of Mass.
The torque Specify Axis allows you to determine which axis the torque is exported around, especially useful for geometry that is not aligned along the X,Y or Z axis or if the Center of Mass is not known. The following example shows the auger with a specified rotation.
Following is the recommended torque export.
The torque is exported along the user-defined axis which matches the axis of rotation of the auger.
Contacts Elements
| Contact Normal (Polyhedral) | X, Y, Z | Standard, Avg., Total, Min. or Max |
Contact vector 1. |
Magnitude, X, Y, Z. |
Standard, Avg., Total, Min. or Max. |
Contact vector 2. |
Normal force. |
Normal overlap. |
N/A |
Number of contacts. |
N/A |
| Overlap Volume (Polyhedral) | N/A | Standard, Avg., Total, Min. or Max. |
| Penetration Depth (Polyhedral) | N/A | Standard, Avg., Total, Min. or Max |
Position |
X, Y or Z |
N/A |
Tangential force |
Tangential overlap |
N/A |
Custom property |
Depends on number of elements |
Bond Elements
Affects all or any combination of specific particles types.
End time. |
N/A |
N/A |
Normal force. |
Normal moment. |
No. of broken bonds. |
N/A |
N/A |
No. of intact bonds. |
N/A |
N/A |
Tangential force |
Tangential moment |
Geometry Elements
Affects all or any individual section (as specified in the Creator).
Center of mass. |
X, Y, Z |
Compressive force. |
N/A |
ID |
N/A |
N/A |
Node n. |
X, Y, Z |
N/A |
Orientation |
All, XX, XY, XZ, YX, YY, YZ, ZX, ZY, ZZ |
N/A |
Position |
X, Y, Z |
N/A |
Power |
N/A |
Total (-ive indicating power required to do work on particles) |
Pressure |
N/A |
Standard, Total Pressure, Max, Min |
Surface normal |
All, X, Y, Z |
N/A |
Torque |
Standard, Avg., Total (Specify Axis), Min. or Max |
Total force |
Velocity |
Standard, Avg., CoG, Min. or Max |
Angular velocity |
Custom property |
Particle Elements
Affects all or any individual particle type (as specified in the Creator).
Angular velocity |
Axial stress |
X, Y, Z |
Compressive force |
N/A |
Coordination Number |
N/A |
Diameter |
N/A |
ID |
N/A |
N/A |
Moment of inertia |
Kinetic energy |
N/A |
Mass |
N/A |
Number of particles |
N/A |
Avg., Total, Total over time, Min. or Max |
Orientation |
N/A |
Position |
X, Y or Z |
N/A |
Potential energy |
N/A |
Residence Time |
N/A |
Standard, Avg., Min or Max |
Rotational kinetic energy. |
N/A |
Stress tensor. |
Torque |
Total energy |
N/A |
Total force |
Velocity |
Volume |
N/A |
Von Mises |
N/A |
Custom property. |
Depends on the number of elements |
The stress tensor for a single discrete element (particle) is calculated as follows:
Vp is the volume of the particle p, npc the number of particles in contact with the particle p, Sc the vector connecting the particle center with the cth contact point and Fc the cth contact force.
For averaging in a representative volume (bin), the stress tensor must be divided by the volume of the bin.
Axial stresses are calculated as follows:
Von Mises stresses are calculated as follows:
Used to remove results data (time steps) from your simulation. Data can be removed entirely, or simply 'thinned out' by removing every nth result.
| Length (bounding box, extent or distance based) |
N/A |
Mass |
N/A |
| Number of Particles |
N/A |
| Volume |
N/A |
| Position | X, Y, Z |
| Number of Elements | N/A | Standard, Avg., Total, Min. or Max |
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
