Setting a Size Distribution for Particle Shapes
You must set the size distribution for the particle shapes in each Bulk Material including Meta-Particles. The scaling options for the size distributions are relative to the defined particle size.
Following are the size distribution options:
(c) 2022 Altair Engineering Inc. All Rights Reserved.
