The Edinburgh Elasto-Plastic Adhesion Model (EEPA)
The Edinburgh Elasto-Plastic Adhesion Model (EEPA) captures the history dependence and the key characteristic behavior of cohesive solids. The flow behavior and handling characteristics of cohesive granular solids are strongly dependent on the prior consolidation stress experienced by the solid.
The model comprises a nonlinear hysteretic spring model to account for the elastic-plastic contact deformation and an adhesive force component that is a function of the plastic contact deformation. The EEPA offers a versatility that allows it to be used in both linear and non-linear modes (Thakur, et al. 2014). When two particles or agglomerates are pressed together, they undergo elastic and plastic deformations. It is assumed that the pull-off strength (adhesion) increases with an increase of the plastic contact area. The contact force-displacement relationship for microscopic particles are shown in the following figure. For more information, see (Jones, 2003), (Jones, 2004).
The force-separation curves from AFM is a schematic illustration of observed force-separation curves for adhesive particles, as adapted from Jones:
In addition to the base interaction parameters in EDEM (Coefficient of Restitution, Static Friction and Rolling Friction) there are six additional parameters to configure for the EEPA model.
The loading, unloading, and adhesive conditions are described by the following six parameters:
Figure 2 demonstrates the linear and non-linear contact force-overlap relationship - schematic of the non-linear (a) and linear (b) contact force–displacement function (Thakur, et al. 2014).
Model Versatility
  1. The non-linearity of the loading and unloading branches is controlled by the parameter n. When n=1, there is linear behavior (Fig.2(b)), and the model replicates a linear spring, whereas when n=1.5 the model replicates the Hertzian spring model.
  2. If the level of contact plasticity, λp, is set to zero then the magnitude of the virgin loading stiffness k1 and the unloading/reloading stiffness k2 are equal and the model reverts to being an elastic model.
  3. The tangential stiffness multiplier, ζtm, defines the ratio of the tangential to normal stiffness and varies depending on the contact model being used. For the case of linear elastic particle contact a value of 1 equates the normal and tangential stiffness. The ratio of tangential to normal stiffness for real elastic materials lies in range of 2/3 to 1, and depends on Poisson’s ratio (Mindlin 1949). The user should consult the relevant literature for exact values of ζtm. Also, the presented values may not necessarily apply for cohesive, plastic contacts.
These parameters are retained as constants for the duration of the simulation. You can change the parameters at any time once the simulation is stopped. You must then restart the simulation.
(c) 2022 Altair Engineering Inc. All Rights Reserved.
