The Hertz-Mindlin with JKR model
Hertz-Mindlin with JKR (Johnson-Kendall-Roberts) Cohesion is a cohesion contact model that accounts for the influence of Van der Waals forces within the contact zone and allows you to model strongly adhesive systems, such as dry powders or wet materials. In this model, the implementation of normal elastic contact force is based on the Johnson-Kendall-Roberts theory (Johnson, Kendal and Roberts 1971).
Hertz-Mindlin with JKR Cohesion uses the same calculations as the Hertz-Mindlin (no slip) contact model for the following types of forces:
  1. Tangential elastic force
  2. Normal dissipation force
  3. Tangential dissipation force
JKR normal force depends on the overlap δ and the interaction parameter, surface energy γ as follows:
Here, E* is equivalent Young’s modulus, and R* is the equivalent radius defined in the “Hertz-Mindlin (no slip) Contact Model” section.
Normal force is a function of normal overlap. Hertz-Mindlin with JKR cohesion model results are compared with the Hertz-Mindlin (no slip) model results. Negative overlap is the gap between two separated particles.
The EDEM JKR normal force follows the same solution of the above equations for both loading and unloading phases. The figure shows the typical plot of JKR normal force as a function of normal overlap.
For γ = 0, force turns into Hertz-Mindlin normal force
This model provides attractive cohesion forces even if the particles are not in physical contact. The maximum gap between particles with non-zero force is defined as:
For δ< δc , the model returns zero force. The maximum value of the cohesion force occurs when particles are not in physical contact and the separation gap is less than δc. The value of maximum cohesion force, called pull-out force, is defined as:
Friction force calculation is different than in the Hertz-Mindlin (no slip) contact model in that it depends on the positive repulsive part of JKR normal force. As a result, the EDEM JKR friction model provides higher friction force when cohesion component of the contact force is higher. The importance and advantages of this friction force model correction in the presence of strong cohesive forces was noted and illustrated in, such as (Baran, et al. 2009), (Gilabert, Roux and Castellanos 2007).
Although this model was designed for fine, dry particles, it can be used to model wet particles. The force needed to separate two particles depends on the liquid surface tension γc and the wetting angle θ:
Equating the above force to JKR max force allows JKR surface energy parameter estimation if EDEM particle size is not scaled.
Interaction Configurable Parameters Position
Particle to Particle,
Particle to Geometry
Click + to add cohesion to particle-particle or particle-geometry interactions. Set the surface energy for each interaction. Surface energy is a property of the materials ability to retain moisture/charge on its surface. The amount of surface energy influences the adhesion of the material. The SI units of surface energy are J/m². Last
  1. Select the required category from the Interaction pulldown in the Physics section of the Creator.
  2. Click the + dropdown and then select Hertz-Mindlin with JKR Cohesion.
  3. Click the configuration  icon to define contact model parameters.
Note: It is not recommended to use this contact model with particle contact radius on since this will result in an attractive force before a physical contact has been made (see Hertz-Mindlin with JKR Version 2).
(c) 2022 Altair Engineering Inc. All Rights Reserved.
