You can import field data from an industry-standard CGNS file or from a custom text file. When using CGNS, you can select multiple files at the same time to speed up importing.
By default, imported fields are not displayed in the Viewer Window, to display a field in the Creator select the relevant field from the drop down menu and select the Display Field checkbox.
Scalar fields are displayed in the viewer as points in 3D space. Vector fields are displayed as arrows,the color and scale of the field can also be modified. The Analyst documentation has further information on post-processing options for Field Data.
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
