Selecting Units
You can configure the units of measurement used throughout EDEM. Select Tools > Options > Units to change units individually, or otherwise.
By default, all quantities are measured in standard S.I. units (Système International d'Unités).
Changes are applied throughout EDEM*
Property Available Units S.I. Unit
Acceleration
mm/s2, cm/s2, m/s2, in/s2, ft/s2, fpm/s, μm/s²
m/s2
Angle
rad, deg
rad
Angular Acceleration
rad/s2, deg/s2
rad/s2
Angular Velocity
rad/s, deg/s, rpm
rad/s
Charge
nC, C
C
Density
g/cm3, kg/m3, lb/in3, lb/ft3, slug/ft3
kg/m3
Energy
J, erg, kwh, btu, ft-lbf, in-lbf
J
Force
N, dyn, kgf, lbf, ozf, pdl, gf
N
Frequency
Hz, kHz, mHz
Hz
Heat Flux
W, J/S
W
Length
mm, cm, m, in, ft, μm
m
Mass
mg, g, kg, lb, oz
kg
Mass Flow Rate
mg/s, g/s, kg/s, lb/s, oz/s, mg/min, g/min, kg/min, lb/min, oz/min, kg/h, uk ton/h, us ton/h, metric tonne/h
kg/s
Moment of Inertia
lb/ft2, kg/m2, g/cm2, lb/in2, slug/ft2
kg/m2
Pressure
Pa, N/m2, dyn/cm2, kp/cm2, atm, Torr, lb/in2
Pa
Shear Modulus
Pa, ksi
Pa
Stiffness
N/m, lb/ft
N/m
Stress
Pa, Nm2, lb/in2
Pa
Temperature
K, oC, oF
K
Time
s, min
s
Torque
Nm, Dyne.cm, gf-cm, kgf-m, lbf-in, lbf-ft
Nm
Velocity
mm/s, cm/s, m/s, in/s, ft/s, ft/min, μm/s
m/s
Volume
mm3, cm3, m3, in3, ft3, L , μm³
m3
Work Function
J, eV
J
*Graphs are not automatically updated when units are changed. Once units have been changed, click Create Graph to regenerate graphs.
(c) 2022 Altair Engineering Inc. All Rights Reserved.
