ThyristorCenterTap2Pulse
Two pulse thyristor rectifier with center tap
Electrical/PowerConverters/ACDC
General information about AC/DC converters can be found at the AC/DC converter concept
This a two pulse thyristor rectifier with center tap. In order to operate this rectifier a voltage with center tap is required. The center tap has to be connected with the negative pin of the load. The circuit topology is the same as in Examples.ACDC.RectifierCenterTap2Pulse.
mo_RonThyristor | RonThyristor | Closed thyristor resistance | Scalar | |
mo_GoffThyristor | GoffThyristor | Opened thyristor conductance | Scalar | |
mo_VkneeThyristor | VkneeThyristor | Thyristor forward threshold voltage | Scalar | |
mo_offStart_p | offStart_p | Boolean start value of variable thyristor_p.off | Scalar | true |
mo_offStart_n | offStart_n | Boolean start value of variable thyristor_n.off | Scalar | true |
mo_T | T | Fixed device temperature if useHeatPort = false | Scalar | |
mo_m | m | Number of phases | Scalar |
mo_useConstantEnable | useConstantEnable | true = disabled boolean input, use constantEnable | Number | 0 |
mo_constantEnable | constantEnable | Constant enabling of firing signals | Scalar | true |
mo_vAC | vAC | vAC | Structure | |
mo_vAC/fixed | fixed | Cell of scalars | true | |
mo_vAC/start | start | Cell of scalars | ||
mo_iAC | iAC | iAC | Structure | |
mo_iAC/fixed | fixed | Cell of scalars | true | |
mo_iAC/start | start | Cell of scalars | ||
mo_powerAC | powerAC | powerAC | Structure | |
mo_powerAC/fixed | fixed | Cell of scalars | true | |
mo_powerAC/start | start | Cell of scalars | ||
mo_vDC | vDC | vDC | Structure | |
mo_vDC/fixed | fixed | Cell of scalars | true | |
mo_vDC/start | start | Cell of scalars | ||
mo_iDC | iDC | iDC | Structure | |
mo_iDC/fixed | fixed | Cell of scalars | true | |
mo_iDC/start | start | Cell of scalars | ||
mo_powerDC | powerDC | powerDC | Structure | |
mo_powerDC/fixed | fixed | Cell of scalars | true | |
mo_powerDC/start | start | Cell of scalars | ||
mo_LossPower | LossPower | LossPower | Structure | |
mo_LossPower/fixed | fixed | Cell of scalars | true | |
mo_LossPower/start | start | Cell of scalars | ||
mo_T_heatPort | T_heatPort | T_heatPort | Structure | |
mo_T_heatPort/fixed | fixed | Cell of scalars | true | |
mo_T_heatPort/start | start | Cell of scalars | ||
mo_enable | enable | enable | Structure | |
mo_enable/fixed | fixed | Cell of scalars | true | |
mo_enable/start | start | Cell of scalars | ||
mo_fire_p | fire_p | fire_p | Structure | |
mo_fire_p/fixed | fixed | Cell of scalars | true | |
mo_fire_p/start | start | Cell of scalars | ||
mo_fire_n | fire_n | fire_n | Structure | |
mo_fire_n/fixed | fixed | Cell of scalars | true | |
mo_fire_n/start | start | Cell of scalars |
ac_p | implicit | Positive AC input | input | 1 |
ac_n | implicit | Negative AC input | output | 1 |
dc_p | implicit | Positive DC output | input | 2 |
fire_p | implicit | Firing signal of positive potential transistor | input | 3 |
fire_n | implicit | Firing signal of negative potential transistor | input | 4 |
Port 6 | implicit | Conditional heat port | input | mo_useHeatPort |
Port 7 | implicit | Enables fire and notFire | input | 1-mo_useConstantEnable |
