The following code generation options are available for each target.
Target |
RAM |
FLASH |
AMD64 |
P |
Arduino |
P |
ARM Cortex M3 |
P |
P |
C2000 |
P |
P |
MSP430 |
P |
Raspberry Pi |
P |
STM32 |
P |
You can also generate C code that can be ported to other platforms for compilation and linking, provided you have an ANSI C compiler and the C-Code Support Library Source Code.
You can also generate code in batch mode that runs in FLASH.
