There are two ways to integrate handwritten code with Embed-generated code:
•Make Callable from User App option
•Use the Extern Read and Extern Write blocks
•Use the Extern Definition and Extern Function blocks
Regardless of the method you use, to run independently but communicate with Embed, use the Extern Read and Extern Write blocks.
