The View menu lets you change the appearance of your blocks, diagrams, and window elements. The table below describes the View menu commands.
View command |
How it affects the window |
Block Labels |
Displays user-specified labels. |
Colors |
Connector Labels |
Displays user-specified labels next to the tab or in the pop-up text when you probe a signal. |
Control Panel |
Data Types |
Colors connectors according to their data type. |
Display Mode |
Hides wires and connectors, freezes blocks in place,
and except for interactive elements on buttons and sliders, locks block
parameter values. If you have inserted a Display Image block in the diagram, it will
not be seen until you simulate the diagram. |
Fonts |
Changes the fonts used to display such things as block names and labels. |
Output Console |
Presentation Mode |
Hides input connectors and shrinks output connectors. |
Status Bar |
Toolbar |
Zoom In, Zoom Out |
Controls how large or small blocks appear in the diagram. |
