You can write an implicit static solver as a DLL. To do so, activate the User Defined parameter in the Simulate > Optimization Properties dialog. A user-written solver is then used. Note the following about a user-written solver:
•It must be named VSOLVER.DLL
•It must reside in your current directory when you initiate implicit static solving
•It must contain the exported function userSolver() that is called at each time step
