Block Category: Signal Producer
The parabola block creates a parabolic signal.
Slope Rate: Scales the curvature of the parabola. The default is 1. You can enter a value in hexadecimal notation or as a C expression.
Time Delay: Indicates an offset that is used in the calculation of a signal. For a constant-valued delay, wire the block into a unitDelay or timeDelay block with an initial condition of the desired constant value. The default is 0 sec. You can also enter in hexadecimal notation or a value as a C expression.
