Resource |
How to access it |
Embed forum |
Embed has an active online community forum where you can post questions, get answers, and promote conversations with other Embed users. |
How-to tutorial |
The Embed How-To Tutorial is a compilation of common simulation and code generation tasks to get you started learning and improving your Embed skills. You can download the tutorial from the Altair Documentation Center. |
Online and local help |
Embed offers both online and local Help. By default, Embed is installed with online Help; local Help is an optional, separate installation that you can download from Altair Marketplace. You can switch between online and local Help with the Help > Set Help Source command. Embed uses your current Browser when displaying Help. There are three versions of Embed software—Embed Pro, Embed SE, and Embed Basic—described under Embed product family. Help is available for all three versions, and for simplicity, Help always refers to the product as Embed, regardless of the version you are using. Sections that do not apply to a specific version are properly noted. |
Sample diagrams |
Your Embed software includes a directory of fully documented sample diagrams. These diagrams illustrate both simple and complex models spanning a broad range of engineering disciplines, including aerospace, biophysics, chemical engineering, control design, dynamic systems, electromechanical systems, environmental systems, HVAC, motion control, process control, and signal processing. All sample diagrams are located under the Examples menu. |
Technical support |
Send an email to embed-support@altair.com and include the following: •Brief description of your issue •Block diagram in question •vissim.ini file •Software version |
Videos |
The Embed video repository contains a growing collection of videos that offer quick and easy ways to learn basic concepts in Embed. Each video focuses on a specific Embed feature. If you are a new Embed user, a good video to start with is Introduction to Altair Embed. |
