Add-On Module |
Description |
Embed/Core Source Code Library |
Contains pre-compiled functions for core blocks that are not translated into inline code. Target is the PC. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Target Source Code Library |
Provides source code for target-specific blocks not translated into inline code. You choose the target: AMD64, Arduino, Raspberry Pi, STMicroelectronics, Texas Instruments. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Comm |
Simulates end-to-end communication systems at the signal level using 200+ communications, signal processing, and RF blocks. Available for Embed SE and Embed. The blocks are for simulation only. |
Embed/Digital Power Designer |
Provides high-level blocks for simulation and code generation of power supply and digital power components and controls. Available only for Embed. |
Embed/eDrives |
Provides an efficient environment covering all phases of developing control systems for electric drives. |
