PCB Formats for Import
View the supported ECAD file formats for import into CADFEKO.
Note: The ECAD file formats are only supported on Microsoft Windows.
The following file formats are supported:
Figure 1. An example of a PCB import.
- Altium
- Designer (.pcbdoc)
- PCAD (.pcb)
- AutoDesk - Eagle (.brd)
- Cadence
- Allegro (folder)
- Specctra/OrCAD Layout (.dsn)
- CADVANCE (folder)
- IPC2581 (.xml)
- Mentor Graphics
- Board Station (folder)
- Neutral (folder)
- Xpedition (folder)
- PADs (.asc)
- ODB++ (.tgz, .tar.gz)
- Zuken
- CADSTAR (.cpa)
- CR5000/CR8000 (.pcf, .pnf, .ftf)
- CR5000 PWS (.bsf, .ccf, .mdf, .udf, .wdf)
- PEMA (Altair) (.pema)
