ROTATION_FORCE
Specifies rotational force resulting from use of rotating frame of reference (obsolete command).
AcuSolve Command
ROTATION_FORCE("name") {parameters...}
Qualifier
User-given name.
- centrifugal (boolean) [=off]
- Flag specifying whether to apply centrifugal force.
- coriolis (boolean) [=off]
- Flag specifying whether to apply coriolis force.
- rotation_center or center (array) [={0,0,0}]
- Center of rotation, specified in global xyz coordinate system. Used with centrifugal force.
- angular_velocity or ang_vel (array) [={0,0,0}]
- Vector of angular velocity of the rotating frame, in radians per unit of time.
This command is obsolete and will be removed eventually. The REFERENCE_FRAME command should be used instead.
is the
viscous stress tensor; x is the current
coordinate vector;
is the
center of rotation, given by rotation_center; and Ω is the
angular rotation rate vector, given by angular_velocity.
ROTATION_FORCE commands are referenced by
BODY_FORCE commands, which in turn are referenced by
ELEMENT_SET
commands:ROTATION_FORCE ( "rotating frame" ) {
centrifugal = on
coriolis = on
center = { 0, 0, 0 }
angular_velocity = { 0, 1, 0 }
BODY_FORCE( "my body force" ) {
rotation_force = "rotating frame"
ELEMENT_SET( "fluid in rotating frame of reference" ) {
body_force = "my body force"
}In this example, the frame of reference rotates around the y axis at the rate of one radian per unit of time, with the axis of rotation centered at the point (0,0,0) in the global xyz coordinate system. The right hand rule is used to define the direction of rotation of the reference frame.
