From the top of the Selections sub-window, select the Added or Removed radio button.
Several options can be used in order to select nodes:
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
o | The default box is rectangular. |
o | Use the SHIFT key to define a polygon box. |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
• | Enter the node identifier number in the Node by Id window and click Ok. |
• | Create and/or modify a box definition. |
• | Inc. conn. nodes |
o | Switch on: automatically include the connections nodes (spotwelds, glue, etc.). |
o | Switch off: automatically remove the connections nodes (spotwelds, glue, etc.). |
• | Inc. RB main nodes |
o | Switch on: automatically include the main nodes of the rigid bodies which have all secondary nodes included in the group. |
o | Switch off: automatically remove the main nodes of the rigid bodies which have all secondary nodes included in the group. |
• | No selection change |
o | Switch on: retain the same include selection as before the group modification. |
o | Switch off: update the same include nodes list. |
Note: It is recommended to keep these default options.
