COSIN/io 2D Road Type: file
Name of input variable | Unit | Meaning |
file_name | - | Name of a file to read measured or calculated data from. The file must be in
standard or Matlab format (cf. COSIN/io documentation). COSIN/road expects equidistant road profile height data as columns of the matrix stored in the file, and optionally banking angles of left and right track. Unit is [m] and [deg], respectfully. |
channel_left_track | - | Column index of left track data |
channel_right_track | - | Column index of right track data. May coincide with channel_left_track, if only one track is measured and/or stored. |
channel_left_banking_angle | - | Column index of banking angle of left track (given in deg). If this index is not specified, banking angle of left track is set to 0. |
channel_right_banking_angle | - | Column index of banking angle of right track (given in deg). May coincide with channel_left_banking_angle, if only one track is measured and/or stored. If this index is not specified, banking angle of right track is set to 0. |
meas_distance | mm | Distance between two consecutive measured points in longitudinal direction. Travel distances outside the range of data in the file get a road height by extrapolation. |
track_linked_to_course | 0/1 | Flag whether track (or road) has to be linked to the actual vehicle course (i.e. whether the vehicle travel path is used to determine the look-up distance in the road profile). If the vehicle stops on the road, due to numerical reasons, track_linked_to_course = 0 is recommended. |
