COSIN/io 2D Road Type: plank or cleat
Name of input variable | Unit | Meaning |
height | mm | Height of plank/cleat. |
start | m | Start of plank/cleat (travel distance). |
length | mm | Length of plank/cleat, measured along x axis. |
bevel_edge_length | mm | Length of bevel edge, measured along x axis. Bevel edge has 45deg slope. With edge_rounded = 1, rounded corners instead of bevel edges are used. In this case, bevel_edge_length is radius of the corner. |
edge_rounded | 0/1 |
direction | deg | Direction of plank/cleat relative to y axis. direction = 0 if plank/cleat is placed crosswise. |
mu_factor_cleat | - | Friction value factor on plank/cleat. |
