A Response Variable can be used to understand the behavior of
a system. Response is generally a scalar output value that can be captured from a solver
expression or a user defined subroutine. Response variables help in calculating the
sensitivity of a system for a given set of design variables.Nine types of response
variables are available by default to choose from.
