Curb to Curb Diameter and Ackerman 1 and 2
Request Number: 80000290
.plt Files | .abf, .mrf Files | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Curb to Curb Diameter (Method 1) | m | The first method of calculating the approximate diameter of the circle the
vehicle would move around at the current steer angles assuming no rear wheel steer.
F3 | RESULT(3) | Percent Ackerman (Method 1) | % | The first method of calculating percent Ackerman. Ackerman is used to
quantify the amount of scrubbing occurring on the front of the vehicle during a
turn assuming no rear wheel steer. A vehicle whose front wheels are parallel (the
same steer angle) has 0% Ackerman. Conversely a vehicle is said to be 100%
Ackerman when the lines through the left and right spindle axes intersect in the
top view at a lateral line passing through the rear wheel centers. The following
equation is used to calculate percent Ackerman with Method 1. See F2/RESULT(2)
above for intermediate term calculations.
F4 | RESULT(4) | Ackerman Deviation (Method 1) | deg | The first method of calculating Ackerman deviation. Ackerman deviation, like
percent Ackerman, is used to quantify the amount of scrubbing occurring on the
front of the vehicle during a turn assuming no rear wheel steer. Zero Ackerman
deviation means that lines through the left and right spindle axes intersect in
the top view at a lateral line passing through the rear wheel centers. The
following equation is used to calculate Ackerman deviation with Method 1. See
F2/RESULT(2) above for intermediate term calculations. alpha = atan((wheel base)/((turn radius)+track/2)) deviation = (outer-alpha)*rtod |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Curb to Curb Diameter (Method 2) | m | The second method of calculating the approximate diameter of the circle the
F7 | RESULT(7) | Percent Ackerman (Method 2) | % |
The second method of calculating percent Ackerman. See F3/RESULT(3) above for an explanation of Percent Ackerman. See F6/RESULT(6) above for intermediate term calculations. alpha = atan((wheel base)/((turn radius)+track/2)) percent Ackerman = (inner-outer)/(inner-alpha)*100 |
F8 | RESULT(8) | Ackerman Deviation (Method 2) | deg | The second method of calculating Ackerman deviation. See F4/RESULT(4) above
for an explanation of Ackerman deviation. See F6/RESULT(6) and F7/RESULT(7) above
for intermediate term calculations. deviation = (outer-alpha)*rtod |
