Curb to Curb Diameter and Ackerman 3 and 4
Request Number: 80000300
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Not Used | Not Used | Not Used |
F3 | RESULT(3) | Not Used | Not Used | Not Used |
F4 | RESULT(4) | Percent Ackerman (Method 3) | % | The third method of calculating percent Ackerman. Ackerman is used to
quantify the amount of scrubbing occurring on the front of the vehicle during a
turn assuming no rear wheel steer. A vehicle whose front wheels are parallel (the
same steer angle) has 0% Ackerman. Conversely a vehicle is said to be 100%
Ackerman when the lines through the left and right spindle axes intersect in the
top view at a lateral line passing through the rear wheel centers. The following
equation is used to calculate percent Ackerman with Method 3.
F5 | Not Used | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Curb to Curb Diameter (Method 4) | m | The fourth method of calculating the approximate diameter of the circle the
vehicle would move around at the current steer angles assuming no rear wheel steer.
F7 | RESULT(7) | Percent Ackerman (Method 4) | % | The fourth method of calculating percent Ackerman. See F4/RESULT(4) above for
an explanation of Percent Ackerman. See F6/RESULT(6) for intermediate term calculations.
F8 | RESULT(8) | Ackerman Deviation (Method 4) | deg | The fourth method of calculating Ackerman deviation. Ackerman deviation, like
percent Ackerman is used to quantify the amount of scrubbing occurring on the
front of the vehicle during a turn assuming no rear wheel steer. Zero Ackerman
deviation means that lines through the left and right spindle axes intersect in
the top view at a lateral line passing through the rear wheel centers. The
following equation is used to calculate Ackerman deviation with Method 4. See
F6/RESULT(6) above for intermediate term
calculations. deviation = (outer-alpha)*rtod |
