If desired, define the solver differential equation using the User-Defined tab, which
        will allow you to specify the properties of the equation using user subroutines.
                From the Properties tab, click the User-defined
                        properties check box.
                Click the newly added User-Defined tab.
                Define the user subroutine.
                        Provide an expression with the USER solver function with parameters
                            being passed to the user subroutine.
                        Alternatively, activate the Use local file and function
                                name check box to specify a local file where the
                            subroutine code can be accessed by the solver.
If this option is not specified, MotionSolve will search for a subroutine following its user subroutine
                                loading rules.
                        Select a function type from the drop-down menu.
                        Select the local file for the subroutine.
The type of file to be specified will depend on the selected function
                            type. For example, if DLL/SO is selected, you can
                            specify a file with a .dll extension (for Windows)
                            or an .so extension (for Linux).
                        Specify the function name in the subroutine that defines the entity, or
                            accept the default name provided by MotionView.
