Catenary Curve of a Cable Hanging under its Own Weight
Model Description
Model location: <altair>\utility\mbd\nlfe\validationmanual\model6.mdl
This model consists of a 20 m length of wire attached between a fixed support at A and a collar at B. The wire has a mass per unit length of 0.2 kg/m. The collar can slide over a cylindrical frame. A horizontal force P of 20 N is applied on the collar.
The sag "h" and the span "L" of the cable is to be found.
Figure 1. Problem Description
Multibody Model
The cable is modeled using 20 NLFE cable elements. The fixed support, frame, and collar are modeled as rigid bodies.
The fixed support and frame are fixed-to-ground using fixed joints. The collar is connected to the frame using a translation joint. The cable is connected to the fixed support and collar using ball joints. A force of 20 N is applied to the collar via a STEP function as:
`Step (time, 0, 0, 5, 20) `
Even though this is a static equilibrium problem, the load is applied gradually and solved for a 10 second quasi-static simulation for the ease of solving.
Figure 2. The Cable Problem Modeled in MotionView
The theoretical solution is as follows.
Sag, h = 4.09 m
Span, L = 17.69 m
This parameter can control the bending stiffness of the cable based on requirement in various cases.
Case 1
Consider the case of a single stranded cable, that is, Number of fibers = 1
If the cable is very slender (for example, 1000 mm length and 0.1 mm diameter), then the bending stiffness is negligible. However, if the cable is less slender (for example, 1000 mm length and 10 mm diameter), the bending stiffness will become significant. In both situations MotionSolve automatically calculates the appropriate bending stiffness.
Case 2
Consider the case of a multi-stranded cable, for example, Number of fibers = X
For a cable that is less slender (for example, 1000 mm length and 10 mm diameter), the overall bending stiffness need not be significant - this is because the interactions between the fibers is a complex phenomenon that can make the bending stiffness negligible. The diameter in this case is calculated based on the cumulative area of all fibers.
Therefore, to get the actual or physical bending stiffness of the cable, the parameter Number of fibers can be tuned in MotionSolve. The bending stiffness of the cable element in MotionSolve decreases as you increase the Number of fibers.
In this particular problem, the calculations assume a theoretical cable with a bending stiffness of zero.
You can try to use the parameter Number of fibers in MotionSolve to see if you are able to get a closer correlation with the results produced assuming a theoretical cable. The number of fibers may need to be increased until the bending stiffness becomes negligible and saturated.
Numerical Results
The initial equilibrium position of the cable system at 0 seconds is shown below in Figure 3:
Figure 3. The Initial Equilibrium Position of the Cable System Seen in HyperView Animation
The final equilibrium position of the cable system at the end of 10 seconds is shown below in Figure 4:
Figure 4. The Final Equilibrium Position of the Cable System Seen in HyperView Animation
The Y position of Point_11 (the mid-point of cable) is plotted to find the sag "h".
The X position of Point_21 (the end-point of cable) is plotted to find the span "L".
Figure 5 below depicts the sag "h" of the cable with parameter Number of fibers = 1.
Figure 5. Plot Showing Sag "h" of the Cable
Figure 6 below depicts the span "L" of the cable with parameter Number of fibers = 1
Figure 6. Plot Showing Span "L" of the Cable
Number of fibers = 20
Figure 7 below depicts the sag "h" of the cable with parameter Number of fibers = 20.
Figure 7. Plot Showing Sag "h" of the Cable
Figure 8 below depicts the span "L" of the cable with parameter Number of fibers = 20.
Figure 8. Plot Showing Span "L" of the Cable
Conclusion
The NLFE model shows close agreement to the theoretical results for this case. You can see that by increasing the number of fibers, you can get closer to the theoretical results (that assumes zero bending stiffness).
The use of fibers is not only for the purpose of matching theoretical results. Any physical case of a multi-stranded cable with any bending stiffness can be modeled by tuning the parameter Number of fibers.
Number of fibers = 1 | Theoretical | Numerical | % error |
Sag "h" | 4.09 m | 4.05 m | 0.98 % |
Span "L" | 17.69 m | 17.74 m | 0.28 % |
Number of fibers = 20 | Theoretical | Numerical | % error |
Sag "h" | 4.09 m | 4.09 m | 0 % |
Span "L" | 17.69 m | 17.70 m | 0.06 % |
