Couple MotionSolve with Activate
MotionSolve can interface with Activate, an open and flexible integration platform for comprehensive system-of-systems simulation.
Activate is based on a hybrid block diagram modeling environment for signal blocks, object oriented physical components, and electric and electronics systems. Use Activate to perform multiphysics analysis throughout the development cycle.
The Value of Coupling MotionSolve and Activate
Implement Coupling
The coupling between MotionSolve and Activate is achieved via co-simulation between the two products. Both products run in parallel, each on their own process (IPC) using their own solver and step-size. Activate is the leading solver and MotionSolve follows. Co-simulation between MotionSolve and Activate can be performed on local or remote computer systems. The interface between MotionSolve and Activate is defined by inputs and outputs in each system. For MotionSolve models, special modeling statements, such as Control: Plant Input and Control: Plant Output, are added to specify its inputs/outputs. These statements reference variables that are either used as inputs to the model (for example, forces or torques) or measure outputs (for example, displacements or velocities). MotionSolve is coupled to Activate either via a proprietary MSPlant/MSSignal block in Activate or via FMU. The former approach is the preferred choice.
MSPlant/MSSignal Coupling
Activate provides the proprietary MSPlant and MSSignal blocks. A MotionSolve model connects to an Activate model directly via one of those blocks. These blocks specify the MotionSolve model and have inputs and outputs based on the ControlPlant elements defined in the model. MSSignal is a variant of MSPlant block that displays the name of MS signals at the input/output ports of the block. Please follow the Activate online help on how to use the MSPlant or MSSignal blocks in Activate.
FMU Coupling
Output
Both solvers generate results for their respective models that can be post-processed within their own software or software tools.
- Activate models can include multiple MSPlant or MSSignal blocks due to the IPC for co-simulation between Activate and MotionSolve. However, only one MotionSolve FMU block is supported in Activate.
- The MSPlant and MSSignal blocks support MotionSolve models that entail compiled and/or scripted user-defined subroutines. The FMU coupling officially does not supports user-defined subroutines.
- Since MotionSolve is the leading solver
for the Altair
EDEM and Altair
OptiStruct coupling, a three-way coupling with
Activate is also supported, where MotionSolve-EDEM/OptiStruct co-simulation is embedded into an Activate model as either an MSPlant or MSSignal
block. The FMU coupling officially does not support a three-way coupling.
- A detailed description of the MotionSolve-Activate co-simulation and its intrinsic workings can be found in the ActivateExtended Definitions for Advanced Users help.
- Detailed step-by-step instructions on how to use a coupling with Activate can be found in MV-7010: Co-Simulation with Activate - Quadrotor Control and MV-7011: Co-Simulation with Activate via Function Mockup Interface (FMI).
