createUJoint
Modeling FunctionDefines a universal joint between two bodies.
createUJoint creates the I and J marker and returns the joint object created. All properties of a universal joint are supported by keyword arguments.
Signature
joint = createUJoint(ibody, jbody, location, ishaft, jshaft, **kwds)
Input Arguments
- ibody
- The first body on which the joint is created.
- jbody
- The second body on which the joint is created.
- location
- The location where the joint is created.
- ishaft
- The direction of ishaft if a Vector is given, otherwise it defines the end point.
- jshaft
- The direction of jshaft if a Vector is given, otherwise it defines the end point.
- kwds
- Keyword arguments that define other properties of the joint.
Return Value
- joint
- The spherical joint created.
Usage
# Create a universal Joint at (1,1,1), ishaft=(1,0,0), jshaft=(0,0,1)
# Method 1: ishaft & jshaft defined by Vector
part1 = Part(mass=1, ip=[10,10,10], cm=Marker())
part2 = Part(mass=1, ip=[10,10,10], cm=Marker())
ibody = part1,
jbody = part2,
location = Point(1,1,1),
ishaft = Vector(1,0,0),
jshaft = Vector(0,0,1),
# Method 2: ishaft & jshaft defined by Point
ibody = part1,
jbody = part2,
ishaft = Point(2,1,1),
jshaft = Point(1,1,2),
