HelicalGear
Model ElementSpecifies a helical gear element.
Class Name
HelicalGear
Attributes
Variable | Type | Notes | Symbol |
id | Int() | Unique identification number. | |
label | Str() | Descriptor of the gear element. | |
rm | Reference("Marker", required=True) | The reference marker of the gear element. This marker points to the center of the gear. Defines the orientation of the gear (z axis of reference marker is the gear’s axial axis). | |
module | Double(required=True) | The normal module of the gear. | |
num_of_teeth | Int(required=True) | The number of gear teeth (see comment 7). | |
pressure_angle | Double(required=True) | The normal pressure angle in degrees. | |
helix_angle | Double(required=True) | The helix angle at the pitch diameter in degrees. | |
width | Double(required=True) | The width of the gear element. | |
addendum_coefficient | Double(1.0) | The basic rack addendum coefficient. | |
dedendum_coefficient | Double(1.25) | The basic rack dedendum coefficient. | |
tool_tip_radius_coefficient | Double(0.38) | The basic rack tool tip radius coefficient. | |
profile_shift_coeff | Double(0.0) | The profile shift coefficient of the gear (see comment 6). | |
hub_diameter | Double(0.0) | The inner/outer diameter of the gear (see comment 8). | |
backlash_ratio | Double(0.04) | The circumferential backlash ratio of the small gear. The range must be 0.03 – 0.05 (see comment 2). | |
addendum_lowering | Double(0.0) | The change to the addendum of the gear teeth due to the profile shift (see comments 1, 3). | |
connection_part | Reference(“Part", required=True) | The part that is connected to the gear. | |
connection_type | Enum("REVOLUTE FIXED", default=" FIXED ") | The type of connection between the gear and the connection part. | |
num_curve_segments | Int(10) | The number of mesh segments along the involute profile of the gear. When using a non-uniform mesh, this parameter is always an even number (the profile is split into two symmetric regions). | |
num_width_segments | Int(20) | The number of mesh segments along the gear's width. | |
non_uniform_factor | Double(1.2) | Defines the factor of the mesh’s non-uniformity. The length of a triamesh element is equal to the previous element length times this factor. Use 1.0 for uniform mesh. | |
density | Double() | The density of the gear's material (see comment 4). | |
export_graphic | Bool(False) | Exports the gear's geometry to a *.stl file. This file can be re-meshed in HyperMesh. | |
export_parameters | Bool(False) | Exports the calculated gear's parameters in a *.json file. |
g = HelicalGear(
id=1,
label='Helical gear',
rm=Marker(part=ground),
module=1.0,
num_of_teeth=17,
pressure_angle=20.0,
helix_angle=15.0,
width=10.0,
addendum_coefficient=1.0,
dedendum_coefficient=1.25,
tool_tip_radius_coefficient=0.38,
profile_shift_coeff=0.0,
addendum_lowering=0.0,
backlash_ratio=0.04,
hub_diameter=0.0,
connection_part = b_shaft,
connection_type='FIXED',
num_width_segments=20,
num_curve_segments=10,
non_uniform_factor=1.2,
density=7.85e-06,
