MAT2
Material Property ElementMAT2 lets you define a hyper-elastic material model for NLFE elements that follows the incompressible Neo-Hookean material law.
<MAT2
id = "integer"
mu = "real"
nu = "real"
rho = "real"
YS = "real"
Attributes
- id
- Unique material property identification number.
- mu
- Shear modulus for the element.
- nu
- Poisson's ratio for the element. Default is 0.49.
- rho
- Element density.
- YS
- An elastic limit for strain. Default is 0.0.
The example demonstrates the definition of a MAT2 element.
<MAT2 id="1" mu="1.906036" nu="0.499" rho="2.150e-6" YS="0.125"/>
- This material element defines a hyper-elastic material that
obeys the incompressible Neo-Hookean law for the strain energy density function:
where
is the shear modulus; , where N is the number of polymer chains per unit volume, K is the Boltzmann constant, and T is temperature
is the bulk modulus
is the Poisson's ratio
Each element must have a unique material identification number.
- This material model can only be used with a fully parameterized element (BEAM12, QUAD12, TRIA12 and solid elements).
- YS lets you specify a maximum limit on the elastic strain that the component is allowed. If, during the simulation, the component strain (at any element in the component) exceeds this value, MotionSolve issues a warning message.
