Optimization Output Data
Every optimization run generates a variety of files.
Figure 1. The output from an optimization of the four bar mechanism
The output from an optimization run is stored in a directory where the simulation was performed. The directory is given a unique name so that it does not conflict with any other existing directory. For the example shown, the directory test-4bar_115807 was created.
Inside this directory, subdirectories and two output files are created.
