The optimization capability in MotionSolve typically involves several solver simulations - one to determine sensitivities for the initial design and several
consequent design simulations to determine and adjust design variables based on responses to satisfy the overall optimization
criteria.
The search method refers to the approach taken in the optimization algorithm to locate a new design point that has
a lower objective function or is more feasible than the current design point.
In this example, we are designing a PID controller whose job is to minimize the effects of a disturbance force on
the position, velocity, and acceleration of a block.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
Optimization Search Methods
The search method refers to the approach taken in the optimization algorithm to locate a new design point that has a lower objective function or is more feasible than the current design point.
