PlanetaryGearSet
Model ElementSpecifies a planetary helical gear set. Construction of (N + 2) Helical gears, which are the sun, the ring, and N planets.
Class Name
PlanetaryGearSet
The planetary gear is defined by the following dimensions (see comments 11, 12, and 13):
The table below summarizes the attributes of the PlanetaryGearSet classes.
Variable Type Notes Symbol
id Int() Unique identification number.
label Str() Descriptor of the gear set element.
rm Reference("Marker", required=True) The reference marker of the gear set element. This marker points to the center of sun and ring gear. Defines the orientation of the gear (z axis of the reference marker is the gear’s axial axis).
rm_2 Reference("Marker") The reference marker of the first planet gear. This Marker needs to have the same orientation of the z-axis with the rm (axial direction), and its origin must be on the plane that is defined from the z axis of the rm (Inplane to the z axis of rm). The operating center distance is calculated from the two reference markers and is used as an input for the gear set (see comment 11).
module Double(required=True) The normal module of the gear. m n
number_of_planets Int(3) The number of planets of the gear set. Ensure that no planet interference occurs (see comment 11). N MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGobaaaa@36E7@
num_of_teeth_1 Int(required=True) The number of teeth on the sun gear (see comment 12). z 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG6bWdamaaBaaaleaapeGaaGymaaWdaeqaaaaa@3828@
num_of_teeth_2 Int(required=True) The number of teeth on gear 2 (see comment 12). z 2 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG6bWdamaaBaaaleaapeGaaGOmaaWdaeqaaaaa@3829@
num_of_teeth_3 Int(required=True) The number of teeth on gear 2 (see comment 12). z 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG6bWdamaaBaaaleaapeGaaG4maaWdaeqaaaaa@382A@
gear_ratio Double(required=True) The gear ratio between the ring and sun gear z 3 / z 1 ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG6bWdamaaBaaaleaapeGaaG4maaWdaeqaaOWdbiaac+cacaWG 6bWdamaaBaaaleaapeGaaGymaaWdaeqaaOWdbiaacMcaaaa@3BD2@ (see comment 13). u MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG1baaaa@370E@
pressure_angle Double(required=True) The normal pressure angle in degrees. a n MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGHbWdamaaBaaaleaapeGaamOBaaWdaeqaaaaa@3847@
helix_angle Double(required=True) The helix angle at the pitch diameter in degrees. β MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaHYoGyaaa@37B5@
width_1 Double(required=True) The width of the sun gear. b 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGIbWdamaaBaaaleaapeGaaGymaaWdaeqaaaaa@3810@
width_2 Double(required=True) The width of the planet gear. b 2 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGIbWdamaaBaaaleaacaaIYaaabeaaaaa@37F2@
width_3 Double(required=True) The width of the ring gear. b 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGIbWdamaaBaaaleaacaaIZaaabeaaaaa@37F2@
addendum_coefficient Double(1.0) The basic rack addendum coefficient. h a * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGObWdamaaDaaaleaapeGaamyyaaWdaeaapeGaaiOkaaaaaaa@3900@
dedendum_coefficient Double(1.25) The basic rack dedendum coefficient. h f * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGObWdamaaDaaaleaapeGaamOzaaWdaeaapeGaaiOkaaaaaaa@3905@
tool_tip_radius_coefficient Double(0.38) The basic rack tool tip radius coefficient. r f * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGYbWdamaaDaaaleaapeGaamOzaaWdaeaapeGaaiOkaaaaaaa@390F@
hub_diameter_1 Double(0.0) The inner diameter of the sun gear. d i 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGKbWdamaaBaaaleaapeGaamyAaiaaigdaa8aabeaaaaa@3900@
hub_diameter_2 Double(0.0) The inner diameter of the planet gear. d i 2 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGKbWdamaaBaaaleaapeGaamyAaiaaikdaa8aabeaaaaa@3901@
hub_diameter_3 Double(0.0) The outer diameter of the ring gear. d o 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGKbWdamaaBaaaleaapeGaam4Baiaaiodaa8aabeaaaaa@3908@
x1 Double(0.0) The profile shift coefficient of the sun gear (see comment 6). x 1 * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG4bWdamaaDaaaleaapeGaaGymaaWdaeaapeGaaiOkaaaaaaa@38E5@
x2 Double(0.0) The profile shift coefficient of planet gear (see comment 6). x 2 * MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG4bWdamaaDaaaleaapeGaaGOmaaWdaeaapeGaaiOkaaaaaaa@38E5@
x3 Double(0.0) The profile shift coefficient of the ring gear. x 3 * MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG4bWdamaaDaaaleaacaaIZaaabaWdbiaacQcaaaaaaa@38C7@
j1 Double(0.04) The circumferential backlash ratio of the sun gear. The range must be 0.03 – 0.05 (see comment 2). j 1 * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGQbWdamaaDaaaleaapeGaaGymaaWdaeaapeGaaiOkaaaaaaa@38D7@
j2 Double(0.04) The circumferential backlash ratio of the planet gear. The range must be 0.03 – 0.05 (see comment 2). j 2 * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGQbWdamaaDaaaleaapeGaaGOmaaWdaeaapeGaaiOkaaaaaaa@38D8@
j3 Double(0.04) The circumferential backlash ratio of the ring gear. The range must be 0.03 – 0.05 (see comment 2). j 3 * MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGQbWdamaaDaaaleaacaaIZaaabaWdbiaacQcaaaaaaa@38BA@
g1_connection_part Reference(“Part", required=True) The part that is connected to the sun gear with a fixed joint.
g3_connection_part Reference(“Part", required=True) The part that is connected to the ring gear with a fixed joint.
carrier_part Reference(“Part", required=True) The part that the planet gears are connected to with a revolute joint constraint.
num_curve_segments Int(10) The number of mesh segments along the involute profile of each gear. When using a non-uniform mesh, this parameter is always an even number (the profile is split into two symmetric regions).
num_width_segments Int(20) The number of mesh segments along the width of each gear.
non_uniform_factor Double(1.2) Defines the factor of the mesh’s non-uniformity. The length of a triamesh element is equal to the previous element length times this factor. Use 1.0 for a uniform mesh.
density Double() The density of the gear's material (see comment 4).
contact_creation Bool(True) Activates an IMPACT contact between the two gears (see Contact IMPACT).
contact_stiffness Double(1e5) Specifies the stiffness parameter of the gear's contact (see Contact IMPACT stiffness).
contact_exponent Double(2.1) Specifies the exponent of the force deformation characteristic of the gear's contact (see Contact IMPACT exponent).
contact_damping Double(1.0) Specifies the maximum damping coefficient that is to be used for generating a damping force on the gear's contact (see Contact IMPACT damping).
contact_dmax Double(0.1) Specifies the penetration at which full damping is applied in the gear's contact (see see Contact IMPACT dmax).
contact_coulomb_friction Enum("ON OFF DYNAMICS_ONLY", default="OFF") Specifies the friction force model that is used to compute the gear's contact friction force (see Contact IMPACTcoulomb_friction).
contact_mu_static Double(0.2) Defines the coefficient of static friction in the gear's contact when the friction is in the static regime (see Contact IMPACT mu_static).
contact_mu_dynamic Double(0.1) Defines the coefficient of the dynamic friction in the gear's contact when the friction is in the dynamic regime (see Contact IMPACT mu_dynamic).
contact_stiction_transition_velocity Double(1.0) Defines the slip velocity at which the static coefficient of friction, mu_static, is applied (see Contact IMPACT mu_ stiction_transition_velocity).
contact_friction_transition_velocity Double(1.5) Defines the slip velocity at which the dynamic coefficient of friction, mu_dynamic, is applied (see Contact IMPACT mu_stiction_transition_velocity).
export_graphic Bool(False) Exports the gears' geometries to two *.stl files. These files can be re-meshed in HyperMesh.
export_parameters Bool(False) Exports the calculated gear set and gear's parameters in a *.json file.
g = PlanetaryGearSet (
    id=1,
    label='Planetary gear set',
    rm=Marker(part=B_Ground),
    rm_2=Marker(part=B_Ground, qp=[center_distance, 0, 0], rm=rm),
    g1_connection_part=b_sun_shaft,
    g3_connection_part=b_ring_shaft,
    carrier_part=b_carrier_shaft,
    module=2.0,
    number_of_planets=3,
    pressure_angle=20.0,
    helix_angle=15.0,
    num_of_teeth_1=35,
    num_of_teeth_2=35,
    num_of_teeth_3=-103,
    gear_ratio=-2.943,
    width_1=20.0,
    width_2=20.0,
    width_3=20.0,
    addendum_coefficient=1.0,
    dedendum_coefficient=1.25,
    tool_tip_radius_coefficient=0.38,
    x1=0.07,
    x2=0.098,
    x3=-1.4288,
    j1=0.04,
    j2=0.04,
    j3=0.04,
    hub_diameter_1=0.0,
    hub_diameter_2=0.0,
    hub_diameter_3=0.0,
    num_width_segments=20,
    num_curve_segments=10,
    non_uniform_factor=1.2,
    density=7.85e-06,
