Utility/SetupUsed in conjunction with SPLINE_READ. It is used to store data read by
SPLINE_READ within MotionSolve.
Use
This function can be called by SPLINE_READ.
CALL PUT_SPLINE(ID, NX, NZ, X, Y, Z, ERRFLG)
Attributes
- ID
- [integer]
- The identifier of the corresponding Reference_Spline
element.
- NX
- [integer]
- The number of elements in the array X. Must be greater
than or equal to 4.
- NZ
- [integer]
- The number of elements in the array Z. Must be greater
than or equal to 1.
- X
- [double precision]
- An array containing X values of the
Reference_Spline element. Length must be greater than
or equal to NX.
- Y
- An array containing Y values of the
or equal to NX times NZ.
- Z
- An array containing Z values of the
or equal to NZ.
Output
- ERRFLG
- [logical]
- A logical flag that represents the success of the
PUT_SPLINE function call. This is checked by
SPLINE_READ.
For an example of PUT_SPLINE, please refer to the
install_path>\hwsolvers\usersub.
