_err.grid file
The _err.grid file is an OptiStruct ASCII format results file.
File Creation
This file is automatically created when freeshape and topography (or shape) optimization runs are terminated due to mesh distortion.
File Contents
- Result
- Description
- Nodal locations
- It contains the nodal coordinates of the distorted mesh for freeshape and topography (or shape) optimization.
File Format
| GRID | Id | Cp | X1 | X2 | X3 | Cd | Ps |
- Data
- Description
- GRID
- Identifies this as a GRID card image.
- Id
- Unique grid point identification number.
- Cp
- Is blank.
- X1, X2, X3
- Provides the location of the grid point in the global coordinate system.
- Cd
- Identification number of the coordinate system in which the displacements, degrees-of-freedom, constraints, and solution vectors are defined at the grid point.
- Ps
- SPC associated with the grid.
