MAT1PT
Bulk Data Entry Defines isotropic permittivity and damping for dielectric materials.
MAT1PT | MID | PMTV | DAMP | ||||||
FLAG1 | FLAG2 |
MAT1PT | 17 | 0.1 | 1.2 | ||||||
STRNCHG | RELATIVE |
MID | Unique material
PMTV | Defines the
permittivity. No default (Real > 0.0) |
DAMP | Damping term corresponding
to the dielectric term. No default (Real > 0.0) |
FLAG1 | Flag to indicate the form
of definition.
FLAG2 | Flag to indicate type of
permittivity.
- The material identification number/string may be the shared with structural material property definitions (MAT1, MAT2, MAT8, MAT9 or MGASK), thermal material property definitions (MAT4, MAT5), or electrical material property definitions (MAT1EC or MAT2EC) but must be unique with respect to other dielectric materials (MAT2PT).
- MAT1PT is supported only for solid elements.
- The material permittivity is obtained as:
(1) Where,- Vacuum permittivity
- Coefficient defined by PMTV
When FLAG=STRNCHG, Strain-Charge form is defined in the card, and the permittivity matrix is expressed as:(2) Where,- Elastic matrix
d
- Piezoelectric coupling matrix defined in MATPZO
- For more information, refer to Piezoelectric Analysis in the User Guide.
