MATTPZO
Bulk Data Entry Defines temperature-dependent coupling terms between structural and dielectric materials, for defining a piezoelectric coupling.
MATTPZO MID T(PIEZO11) T(PIEZO12) T(PIEZO13) T(PIEZO14) T(PIEZO15) T(PIEZO16)
    T(PIEZO21) T(PIEZO22) T(PIEZO23) T(PIEZO24) T(PIEZO25) T(PIEZO26)
    T(PIEZO31) T(PIEZO32) T(PIEZO33) T(PIEZO34) T(PIEZO35) T(PIEZO36)
MATTPZO 1 1011     1014   1016
      1022
        1033
MID Material property identification number.
Must match the identification number on MATPZO Bulk Data Entry.
No default (Integer > 0)
T(PIEZOij) Identification number of the TABLEM1-4 or TABLEG Bulk Data Entries that defines the individual elements of the temperature-dependent piezoelectric coupling matrix. 1
Default = blank (Integer > 0)
  1. The quantities defined on the MATPZO Bulk Data Entry are multiplied by the tabular function referenced by the MATTPZO Bulk Data Entry to generate the corresponding material properties.
  2. If the fields are blank or zero, then constant properties defined on the MATPZO Bulk Data Entry are used.
  3. For more information, refer to Piezoelectric Analysis in the User Guide.
