NLLOAD
I/O Options and Subcase Information Entry The NLLOAD entry can be used to request nonlinear load output for Transient Response Analysis for each time step for all subcases or individual subcases, respectively.
NLLOAD(format, SUBSYS=SUBSYS_ID)= option
Argument | Options | Description |
format | <PUNCH, blank> |
SUBSYS | <SUBSYS_ID> No default |
ID of the subsystem. When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only. For more information, refer to the SET Bulk Data Entry. |
option | <ALL, SID, NONE> |
- Nonlinear loads are output only for Transient Analysis subcases.
