OUTPUT
I/O Options EntryThe OUTPUT command can be used to control the format of results output and the creation of certain results files.
OUTPUT, keyword, frequency, option1, option2, option3
Argument | Options | Description |
keyword | See below | See below |
frequency | FIRST, LAST, FL, ALL, NONE, N, CONV, CURRENT, or blank |
option | See below | See below |
Standard Result Outputs
If a result OUTPUT not defined, the default result output is both HM and H3D. If any result OUTPUT commands exist, there is no default OUTPUT type.
Keyword | Description | Default Frequency | Affected Files | Options | Details |
HM | Output results in HyperMesh binary format. | FL | *.res | <NODMIG, DMIGALL, DMIGSET> | Determines whether or not
to output results for interior points of external superelements.
16
H3D, HV | Output results in Hyper3D format. | FL | *.h3d | <BYSUB, BYITER> Default =
BYSUB
Note: Applicable to optimization runs
only.
Determines the way the output files are arranged in an optimization run. 15 |
16
OP2, OUT2, OUTPUT2 | Output analysis results in Nastran output2 format. | FL | *.op2 | <MODEL, NOMODEL> Default = MODEL |
Turns on/off the output of the model data to the file. 11 12 |
16
NASTRAN, PUNCH, PCH | Output analysis results in Nastran punch format. | FL | *.pch | <NODMIG, DMIGALL, DMIGSET> | Determines whether or not
16
OPTI, ASCII, OS | Output results in OptiStruct ASCII format. | FL | *.cstr, *.dens, *.disp, *.force, *.gpf, *.load, *.mpcf, *.spcf, *.strs | - | For more information about the old and new OPTI formats, refer to PARAM, OPTI. |
PATRAN, APATRAN | Output analysis results in
Patran ASCII
format. (APATRAN uses an alternate file naming convention, with the iteration number after the file extension). |
FL | *.#.#.#.dis,
*.#.#.dis, *.#.#.els,
*.#.dis,
*.#.els, *.#.#.dis.#, *.#.dis.#, *.#.els.#, *.dis.#, *.els.# |
HDF5 | Results are output in the Hierarchical Data Format, Version 5 (.h5 file). 22 | FL | *.h5 | <YES, NO, COMP, NOCOMP> |
NONE | Results are not output in any of the formats listed above. | - | - | - | - |
Optimization Output
DESIGN | Controls the frequency of output for design results such as DENSITY, SHAPE, and THICKNESS. | ALL | All files that design results are written to. | - | CONV is supported as one of the Frequency Options for this output request. CONV is used to output results for the first and all subsequent converged iterations during Topology Optimization. |
SHRES | Controls the frequency of output of the shape files. | L | *.sh,*.grid | - | - |
GRID | Requests the output of the state file (.grid file) for topography or shape optimization. | L | *.grid | <BASIC , LOCAL, DESIGN> |
FSTOSZ | Automatic generation of a sizing model after free-sizing optimization. This is applicable to both composite and non-composite (PSHELL) optimization. 18 | L | *_sizing.fem |
SZTOSH | Automatic generation of a shuffling model after ply-based sizing optimization. | L | *_shuffling.fem | - | - |
FSTHICK | Controls output of free-sizing results to .fsthick file. 13 | L | *.fsthick | <YES,
NO> Default = NO |
DESVAR | Requests the output of updated design variable values. | L | *.desvar, *.out | <FILE, OUT, BOTH, NONE> |
PROPERTY | Requests the output of the
updated property definitions. Note: In the Description
and Details columns of the PROPERTY keyword:
"Property" stands for "Properties, Materials and
Elements".
L | *.prop,*.out | <ANY, DESIGN, FILE, OUT, BOTH, NONE> |
HGSENS | Sensitivity output presentation for HyperGraph. 4 | FL | *_sens.#.mvw, *.#.sens | <ALL,
NOSTRESS, STRESS> Default = NOSTRESS |
MSSENS | Sensitivity output in Microsoft Excel SYLK format. 4 | FL | *.#.slk | <ALL,
ASCSENS | Topology and free-sizing sensitivity (response with respect to design element density) output in ASCII format. | FL | *.#.asens | <ALL,
See Comment 4 |
H3DSENS | Sensitivity output in H3D format.19 | FL | *_dsa.h3d or *_dsa.#.h3d |
<USER,
NOUSER, COMB,
BYITER> Default = NOUSER, BYITER |
H3DSENS is not supported for Free-Shape Optimization. |
H3DTOPOL | Sensitivity output in H3D format for contouring of topology and free-sizing sensitivity. 4 | FL | *_topol.h3d | <ALL,
NOSTRESS, STRESS,
MASS, N,
NOMASS> Default = NOSTRESS, NOMASS |
H3DGAUGE | Sensitivity output in H3D format for contouring of shell thickness sensitivity. 4 | FL | *_gauge.h3d | <ALL,
NOSTRESS, STRESS,
MASS,
NNOMASS> Default = NOSTRESS, NOMASS |
HGHIST | Design history output for HyperGraph. 5 | - | *_hist.mvw, *.hist, *.hgdata | Integer ≤ 32 Default = 31 |
DVGRID | Output of shape variable definitions to .dvgrid file. 6 | - | *.dvgrid | - | |
MSLAGM | Lagrange Multiplier output in Microsoft Excel SYLK format. 21 | L | *.#_lagm.slk | - | |
BORED | Output for bore distortion results in ASCII file format, | FL | *_d.#.bdst,
*_bdst.#.mvw (# is the iteration number). |
- | See Comments 26 and 27 |
Specialized Result Outputs
ADAMSMNF | Output of flexible body to a modal neutral file for MSC.ADAMS. 17 | - | *.mnf | <YES,
NO> Default = YES |
HGFREQ | Frequency Analysis output presentation for HyperGraph. 3 | FL | *_freq.mvw, *_s#_a.frf, *_s#_d.frf, *_s#_v.frf |
HGTRANS | Transient Analysis output presentation for HyperGraph. 2 3 28 | - | *_tran.mvw, *_s#_a.trn, *_s#_d.trn, *_s#_s.trn, *_s#_v.trn |
HGMBD | - | *_mbd.mvw, *_s#_a.mbd, *_s#_d.mbd, *_s#_v.mbd |
HGEFFMASS | Effective mass is output as a HyperGraph bar chart via the BAR option (default), or as a HyperGraph XY plot via XY option. | - | *.mass,
*_mass.mvw |
HGMODFAC | Modal participation factor output presentation for HyperGraph 3D. 14 | FL | *_modal.mvw, *_modal.#.mvw |
<REGULAR, NORM> Default = REGULAR |
MASSPROP | Controls the output of Center of Gravity and Mass Moments of Inertia tables based on properties to .out file. 20 | FL | *.out | - | The center of gravity is specified in the basic coordinate system. The Mass Properties are with respect to the center of gravity of the item. |
MASSCOMP | Controls the output of mass based on HyperMesh components to the .out file. | FL | *.out | - | - |
MODES | Controls the printing of modes to the .out file from normal modes or modal dynamic optimization runs. | ALL | *.out | - | The default is
ALL, that is modes extracted are printed to the
.out file for all optimization
iterations. All frequency options except CONV and CURRENT are applicable to OUTPUT,MODES. |
REGCOMPL | Controls the output of regional compliance table to .out file. | *.out | <YES,
NO> Default = YES |
24 | |
KPI | Controls the output of Key Performance Indicators to .kpi file (ASCII). | FL | *.kpi | - | 24 |
MATRIX | Controls the output of Stiffness, Mass, and Grid-to-DOF mapping matrices to .full.mat and .reduced.mat files (ASCII). | - | *.reduced.mat,
*.full.mat |
Option
1: <FULL, REDUCED> No default Option 2: <DENSE, SPARSE> Default = DENSE Option 3: <'format'> Default = Blank |
The FULL and
REDUCED options control whether the full or
reduced stiffness/mass matrices are output to the .full.mat and .reduced.mat
ASCII files. An additional optional control, DENSE and SPARSE allows control over whether to output the fully dense matrices or to only output the sparse matrices (without zeros). The
third option allows you to control the precision and format of
the output. The format is defined using the Fortran syntax,
which provides the number of entries per line, followed by the
precision.
Note: The format should be enclosed in single
quotes.
A couple of examples:
PCOMP | Output equivalent PCOMPG from the ply-based modeling (STACK/PCOMPP) input. | - | *.pcomp | - | This is supported for analysis and optimization. The Frequency option is not supported for this keyword. |
File Output Controls
TCL | Controls output of .tcl files. | - | *.HM.comp.tcl, *.HM.ent.tcl, *.HM.conn.tcl | <YES,
NO> Default = YES |
OSS | Controls output of .oss file. | - | *.oss | <YES,
NO> Default = YES |
HTML | Controls output of .html file. | - | *.html | <YES,
NO> Default = NO |
SPCD | Controls output of the .spcd file. | - | *_spcd | <YES,
NO> Default = see Comment 25 |
STAT | Controls output of .stat file. | - | *.stat | <YES,
NO> Default = YES |
See Comment 9 |
MVW | Controls output of .mvw file. | - | *.mvw | <YES,
NO> Default = YES |
- Frequency does not apply for any of the keywords where a dash (-) is given as the default frequency in the keywords table above.
- HGTRANS and HGMBD are currently available for analysis only.
- HGFREQ, HGTRANS, and HGMBD will only use output requests where a Set ID is specified. For example, if DISPLACEMENT=ALL or DISPLACEMENT(HG)=ALL is given, displacement information will not be present in the presentation, whereas if DISPLACEMENT=1 or DISPLACEMENT(HG)=1 is given, displacement information will be present in the presentation for the constituent nodes of Set 1.
- For HGSENS,
H3DTOPOL, H3DGAUGE,
ASCSENS, or MSSENS options:
- If NOSTRESS or blank: results are printed, but stress, strain, and force responses are ignored.
- If ALL or STRESS: results are printed, including stress, strain, and force responses.
- If MASS: Mass-normalized sensitivities are output to the corresponding H3D file. This is labeled as “Sensitivity (Mass)” in HyperView.
- For HGHIST options:The integer value given is equal to the sum of the desired options:
- 1
- Design variable.
- 2
- Objective function and maximum % constraint violation.
- 4
- All non-stress responses.
- 8
- All DRESP2 responses.
- 16
- All DRESP3 responses
- 32
- Normalized constraint violation plots. Value 32 outputs the plot for responses divided by their corresponding constraint bounds to the *_hist.mvw file. The response over constraint bound (Y-Axis) versus Response ID (X-Axis) plots are only output for the final optimization iteration. The responses ID’s are not equivalent to the user-defined Response IDs in the model. To identify any response, hover the mouse pointer over red vertical curve in HyperGraph, this will display the user-defined Response Label. The Y-Axis value of 1.0 is displayed as a red horizontal line.
- blank
- All of the above, except 32 are output. So, the default value is 31.
For example: If design variables and all DRESP2 responses are wanted, you would enter 9.
- The DVGRID option creates shape variable definitions for displacement or eigenvector results of Linear Static, Normal Modes, or Linear Buckling Analyses. These shape variable definitions can then be used in subsequent optimizations. This process facilitates the use of "natural" shape functions.
- For the keywords HM, H3D, HV, ASCII, OPTI, OS, NASTRAN, PUNCH, OP2, OUT2, OUTPUT2, PATRAN and APATRAN, the information provided by the OUTPUT I/O Option Entry takes precedence over information provided on the older FORMAT and RESULTS I/O Option Entries.
- OUTPUT entries are read sequentially; therefore, where multiple OUTPUT entries exist with the same keyword, the last instance is used.
- If OUTPUT,STAT,NO is defined, the *.stat file is deleted at the end of the run (as long as the run was successful), but the file always exists during the run.
- OUTPUT,DESIGN takes precedence over the information provided on the older DENSRES I/O Options Entry. OUTPUT,DESIGN will write design results, at the frequency defined, to all active output formats (HM, H3D, or OPTI), regardless of the frequency chosen for that output format. By default, HM is the only active output format.
- When CMSMETH is used, or when a full multibody dynamics run is performed, the CMS stress modes can be written to OP2 format. This only happens when OUTPUT,OP2 is defined. One file for each is generated. Stresses are written for shells and solids, while forces are written for bars/beams and welds. Each mode is written as a static load case with ID equal to the mode index. This output is compatible with FEMFAT by MAGNA.
- The MODEL/NOMODEL option for OUTPUT,OP2 may be overridden by the PARAM, OGEOM Bulk Data Entry.
- The FSTHICK keyword generates a file with the .fsthick extension. The file contains Bulk Data Entries for elements (CQUAD4, CQUAD8, CTRIA3, and CTRIA6) contained in free-size design spaces. The element definitions have the optimized thickness defined as nodal thicknesses (Ti) for each element.
- The HGMODFAC keyword generates a
HyperGraph 3D presentation providing 3D plots of
modal participation factors. The plots display the mode number on the x-axis,
the frequency (for Frequency Response Analysis) or time (for Transient Analysis)
on the y-axis and the modal participation factor on the z-axis.
The NORM option normalizes the participation factors with respect to 1.
In HyperGraph 3D, it is possible to define cross-sections to generate 2D plots of either:- Modal participation factor versus frequency or time for a given number.
- Modal participation factor versus mode number at a given frequency or time.
For Frequency Response Analysis, plots are generated for the real part, the imaginary part and the magnitude of the participation factors. Magnitude plot is visible by default, while real and imaginary plots are hidden by default.
- The H3D output from optimization runs consists of
numerous files. The BYSUB/BYITER option allows
switching between two modes of H3D output. There is a no default option
(BYSUB/BYITER) for analysis runs.
- BYSUB (This is the default option for optimization
runs) outputs one _des.h3d file for the
animation of the optimization history. The frequency of the
optimization results in this file is defined by
OUTPUT, DESIGN (Default =
ALL). In addition, an
_si.h3d file for each subcase i is written
that contains the history of the analysis results for each subcase.
Frequency determines the analysis result output frequency.
Optimization results can be written to the subcase files using
DENSITY, SHAPE, or
THICKNESS output requests.
(Using OUTPUT, H3D, or BYSUB for analysis runs (without optimization) will output the same files as above (except for the _des.h3d file), however no design results or analysis history will be available within the files).
- BYITER outputs one .#.h3d file
per iteration that contains the optimization and analysis results
for all subcases per iteration. Frequency determines at which
iteration these files are created. It overwrites the default of
OUTPUT, DESIGN unless an
actual OUTPUT, DESIGN
statement is present. In the case of a shape optimization, the
GRID coordinates of the model in the
respective iteration are updated to the new shape.
(Using OUTPUT, H3D, or BYITER for analysis runs (without optimization) will output only one .h3d file since there are no multiple iterations). An additional frequency option CURRENT is available for the BYITER option. Therefore, OUTPUT,H3D,CURRENT,BYITER will output a separate H3D file named <filename>_cur.h3d file which contains analysis run output for the current optimization iteration. This file is overwritten for each subsequent optimization iteration.
DENSITY, SHAPE, or
- Results for interior points of external superelements will be output by default to HM, H3D, PUNCH, and OP2 files.
- To output stresses to the .mnf file, the GPSTRESS I/O Options Entry should be specified in addition to OUTPUT, ADAMSMNF. PARAM,GPSLOC can be used to control the output location of stresses for shells (top/bottom/middle).
- For FSTOSZ options:For Composite Optimization:
- Bundles
- Specifies the number of ply bundles to be generated per fiber orientation.
- Method
- Ply bundle thicknesses are determined based on the method defined.
- ADVFREE
- Advanced algorithm with free thicknesses.
- ADVMAN
- Advanced algorithm with manufacturable thicknesses.
- SIMFREE
- Simple algorithm with free thicknesses.
- SIMMAN
- Simple algorithm with manufacturable thicknesses.
The advanced algorithm is available for 2, 4 and 8 ply bundles. The thickness distribution is considered when generating the ply bundles, which results in a more accurate representation of the original free-sized thickness profile.
Ply bundle thickness can also be multiples of the manufacturable ply thickness.
Ignore: Elements may be ignored in a given ply orientation when their thickness is less than 5% of the maximum thickness. This option is inactive by default.
For Non-Composite (PSHELL) optimization:- Bundles
- Specifies the number of PSHELL groups to be generated per PSHELL definition depending on the thickness.
- Method
- Bundle thicknesses are determined based on the method
defined.
- ADVFREE
- ADVMAN
- SIMFREE
- SIMMAN
- Ignore
- Elements may be ignored in a given bundle when their thickness is less than 5% of the maximum thickness.
- H3DSENS, USER
indicates that the user-defined responses should be included in the DSA output.
NOUSER indicates that user-defined responses should not be
included. In both cases, responses defined through the DSA output request are
included in the DSA output. Table 1 lists the sensitivities that are
output for each option.H3DSENS only matters when DSA is used. DSA is supported only for Frequency Response Analysis currently.
Table 1. Output Sensitivities Requested via the DSA Output Request (responses are automatically defined)
Sensitivities Output from a Complete Optimization Setup (User-defined/specified responses via DRESP1, DRESP2, DRESP3)
OUTPUT, H3DSENS, USER Yes Yes OUTPUT, H3DSENS, NOUSER Yes No H3DSENS, BYITER (default) indicates that multiple *_dsa.#.h3d files are output for multiple iterations (#). H3DSENS, COMB indicates that a single combined *_dsa.h3d file is output for all iterations.
- The values of PARAM,GRDPNT and PARAM,UCORD do not affect the output of Center of Gravity and Mass Moment of Inertia output via OUTPUT,MASSPROP. This output is also supported for a check run, which allows checking the center of gravity and mass moment of inertia output before launching a full run.
- Multiple Objective runs, Stress/Strain norm, and BIGOPT optimizer are not currently supported in conjunction with MSLAGM.
- The HDF5 output is printed to a .h5 binary results file. For details of the supported analysis types and elements when the .h5 output format is requested, refer to the .h5 file.
- The FREQUENCY options (except CURRENT) are supported for TCL file output. FAST option is the default.
- KPI output includes maximum value for Displacement, Stress, Strain, and Plastic Strain with respect to the corresponding property. It is supported for linear and nonlinear static analysis only. Stresses and Strains are supported only for shells and solids. This output can also be activated from the corresponding I/O Options Entry ( DISPLACEMENT, etc).
- If
OUTPUT,SPCD is present in the input file, it is
equivalent to OUTPUT,SPCD,YES and the corresponding
*.spcd file(s) are output.
If OUTPUT,SPCD is not in the input file, or if OUTPUT,SPCD,NO is explicitly specified, then the corresponding *.spcd file(s) are not output.
- The output of bore distortion results can be turned off using OUTPUT, MVW, NO.
- OUTPUT, BORED is not supported with the CURRENT option.
- The HGTRANS output request is supported for linear (direct and modal) transient analysis only, in general. Only in case of section force/moment results, it is supported with both linear and nonlinear transient analysis types. The plots are available for magnitude, as well as X, Y and Z components.
