/ADYREL
Engine Keyword Dynamic relaxation with auto-defined adaptive damping.
/ADYREL
Tstart Tstop
Definition
Tstart | (Optional) Start time
for adaptive dynamic relaxation. Default = 0.0 |
Tstop | (Optional) Stop time
for adaptive dynamic relaxation. Default = Final time of the analysis |
- /ADYREL is based on /DYREL but the period to be damped is automatically calculated and varies during the simulation.
- The line with Tstart and Tstop is optional. If the start and stop times are not included the adaptive dynamic relaxation is active until the end time defined by /RUN.
