*AIRBAG_ADIABATIC_GAS_MODEL_ID
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag filed by adiabatic gas. Uniform pressure method is used.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*AIRBAG_ADIABATIC_GAS_MODEL_ID |
monvol_ID | Title |
surf_IDex | Surf_typ | ||||||
Pscale | Gamma | P_int | P_ext |
Definition
monvol_ID | Airbag
identifier. (Integer) |
Title | Title. (Character) |
surf_IDex | Airbag external surface
Surf_typ | Set type.
(Integer) |
Pscale | Scaling factor of internal
pressure. (Real) |
Gamma | Adiabatic
constant. (Real) |
P_int | Initial internal
pressure. (Real) |
P_ext | External
pressure. (Real) |
- This keyword maps to /MONVOL/GAS.
