*AIRBAG_LOAD_CURVE_ID
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with pressure specified as function of time.
(1) (2) (3) (4) (5) (6) (7) (8)
If OPTION = ID, insert the following line
monvol_ID Title
surf_IDex Surf_typ
STIME LCID
Definition
monvol_ID Airbag identifier.
(Integer)
Title Title.
(Character)
surf_IDex Airbag external surface identifier.
(Integer)
Surf_typ Set type.
= 0 (Default)
surf_IDex is a segment set.
0
surf_IDex is a set of parts.
(Integer)
STIME Time shift for pressure application.
(Real)
[ s ]
LCID Load curve ID for pressure versus time.
(Real)
  1. This keyword maps to /MONVOL/PRES.
