/ALE/GRID/SPRING
Block Format Keyword Grid nodes are connected with nonlinear springs (those springs have no effect on the material, only on the movement of the grid).
/ALE/GRID/SPRING | |||||||||
Vmin |
Definition
Typical time
step (Real) |
Nonlinearity
factor Default = 0.0 (Real) |
Damping
coefficient Default = 0.5 (Real) |
Shear factor Default = 1.0 (Real) |
Vmin | Element with a volume less
than Vmin will be
declared Default = -1030 (Real) |
- This option is available for 3D analysis only.
- Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
- Effective time step
is computed using damping parameter:
(1)
